03-29-2006, 05:52 PM
Originally Posted by GChambers
Seats are close to 35lbs each. I would guess that the Mugen seats with sliders would be close to 15lbs each. There is 40lbs total for you. You may also consider looking into the Buddy Club seats. I have heard that they are the same as the Mugen seats but are much less expensive.
Get a header. The stock header, while very efficient, is very heavy as well. A Mugen, J's, Rick's or Toda header will lose about 10 lbs and maybe gain a few hp as well.
Get a set of 17in. Volk CE28Ns. These are absolutely THE BEST WHEELS FOR AN S2000. If anyone says differently, they are wrong. They are the right size, have the perfect offsets and look great. Most importantly, they are the lightest 17in wheel made for the car. They will save you about 4-5lbs of unsprung weight per corner with the right tires.
If you do not need it, get rid of the air conditioning. It is 40-50lbs.
The right exhaust could save you up to 45lbs if you don't mind a lot of noise. I briefly had a Magnaflow Titanium exhaust that weighed about 7lbs. It was loud as hell though. A Mugen exhaust weighs about 25lbs but is very quiet. Almost as quiet as stock. An Amuse Dual Titanium is a bit more expensive than the Mugen but reportedly gains a few more hp and is about 15lbs.
A cold air intake could also save you a few lbs. Most importantly, it will help eliminate the heat soak problem. On a hot day, my AEM V2 probably does not make much hp but it does an excellent job of drawing in cool air as opposed to the hot air from around the radiator.
You could also remove all of the trunk lining along with the tool kit. The trunk lining may weigh about 7-8lbs.
Also, consider getting a nice set of coilovers. Some are much lighter than stock. I am certain my Ground Control/Koni saves a few lbs per corner since the springs are about a third the size of the stock springs.
I, personally would not mess with relocating the battery. It is in a good place to start with. Also, if you relocate the battery, you are going to have to run a new battery cable. This is a very heavy wire so you will actually be adding weight to the car. If you do gut the air conditioning and don't add a stereo amp, you could replace the stock battery with a riding lawnmower battery. They are very cheap and weigh about half of what the stock battery weighs.
I could go on...
In the middle of fantasizing about the S2000 eventually being legal for a SoloII Street Touring class, I figured that I could easily get the car down to a very streetable 2550lbs with little problem and maybe under 2500lbs with some serious effort. With maybe a 10hp bump with all these mods and the lower curb weight, you could go from about 11.7lbs/hp to about 10lbs/hp.
Are the seats comfy?
