Go Back   S2000 Club of America Forums > Public Forums > S2000 Chat > The XViper's Den
The XViper's Den Have a technical question about your S2000? Just ask the experts.
Old 05-03-2007, 11:51 PM
ebeldesign ebeldesign is offline
ringing upon decel
I am getting a ringing sound from the passenger side rear of the car when I let off the gas and coast down between 65 and 55 mph. It is speed dependent, and occurs with the clutch in or out, but not when I have the gas applied or am accelerating. I am guessing it is the rear end...is this something that is indicating a pending failure?
Thanks for any help.
Old 05-03-2007, 11:58 PM
Goku's Avatar
Goku Goku is offline
Lil "Stig" in training.
its in the diff. Mine does it at 55mph excatly. must be coasting or lightly on the gas. any brisk accel and its gone. I've heard that this is normal to a point. There is a TSB on it if I remember right. But its not a sign of impending doom...yet...
Old 05-04-2007, 02:59 AM
repiv's Avatar
repiv repiv is offline
Club Member
Rear diff is a good guess. Try changing the diff fluid. Go with Mobil 1 75W90 GL-5 or LE 607 if you don't drive the car in frigid winter conditions. If you want to stick with a 90 wt lube like what came with the car, then go to a Honda motorcycle shop and buy some SAE 90 Hypoid Gear Oil. This is what Honda recommends you put into your diff. Honda car division has no in-house diff fluid for our cars.
This may or may not get rid of the ringing - depends on exactly what's wrong. Although only a possibility, it could also be a wheel bearing. Have you got an earlier model of S2000 where the hubnut has yet to be updated with the new torque of 221 lb/ft?
Old 05-04-2007, 03:03 AM
silversurferS20's Avatar
silversurferS20 silversurferS20 is offline
i head that noise on my s2k and my rear did end up going KABOOM.....i would say get it checked out...
Old 05-04-2007, 03:05 AM
Jays2k's Avatar
Jays2k Jays2k is offline
My '01 does the same thing. Its at around 3k to 4.5k rpm. repiv can you elaborate more on the hubnut I would like to make sure thats not my problem...and is there a way to check this nut without going to the daler? Thanks for your time and info!!!
Old 05-04-2007, 03:24 AM
repiv's Avatar
Club Member
Absolutely! It's off topic, but it's important enough to justify answering here.
Each back wheel hub is secured by a large "staked" nut (36mm to be exact). Looks like this:
Honda originally stated that this should be torqued to 181 lb/ft. About 2002 or 2003, Honda came out with a TSB indication that if a customer came in complaining about a click upon moving off initially either forward or in reverse, then this hubnut must be torqued to a new recommended 221 lb/ft. What a loose hubnut does is cause too much play for the wheel bearing. This bearing can shift during initial take off and make a click. However, prolonged looseness can wear the wheel bearing and hub abnormally and not only cause this clicking but could also manifest itself in other sorts of noises.
To tighten this, you need to jack up the rear of the car, remove the rear wheels, unstake the nut and take it off. Then you remove the big washer (keeping track of which side is which), clean out any crap and debris you find, apply a light coating of grease to all surfaces, lightly grease the spindle threads (axle grease will do), re-install the washer, re-install the nut, torque to 221 lb/ft and re-stake the nut rim (it should be in a location slightly further than where it was before).
This will ensure the wheel bearing is sufficiently snug in the hub and should prolong the life of it and the hub assembly for a good long time. If caught soon enough, your hub won't know the difference and should last a "lifetime".
Old 05-04-2007, 03:29 AM
Jays2k's Avatar
If I bring my car to the dealer is this something they should take care of no charge for me? Do you know where I can get a list of TSB's?
Old 05-04-2007, 03:33 AM
ive been told honda dealers are very good at blaming things on customer abuse...do you have the warranty on the car?
Old 05-04-2007, 03:36 AM
Jays2k's Avatar
Yes but i just put a fujita f5 intake on it so im i little bit worried about them saying that it voids my warrenty.
Old 05-04-2007, 03:48 AM
you buy the car new or used....if you got it used just tell them that is how you bought it from them
Old 05-04-2007, 03:50 AM
repiv's Avatar
Club Member
An intake doesn't affect how a rear wheel bearing works. However, if your car is old enough that it would still have the old torque setting, you may be out of factory warranty. I don't think an extended warranty would qualify you for this fix. But then, your dealer may do it for you as a "good will" gesture. Best to ask them. It's not a long job and shouldn't cost more than an hour's labour.
As for the TSB, ask your dealer to look this up:
Service Bulletin 011201 Sequence Number: 627 Clicking Rear replaced Hub Nuts
Jays2k's Avatar
I bought it used and thats a great idea!!
Old 05-04-2007, 03:51 AM
Jays2k's Avatar
Thanks repiv your advise has been great!! Do you ever get tired of that line?
  #14
my extended warranty covered my rear hubs and my rear end....i can say i got my moneys worth for it ......
  #15
Old 05-04-2007, 05:43 AM
I have an appointment to have the diff fluid changed in the morning, so I'll update on if that changes the sound or not. My car is an '05, does the TSB still apply?
thanks for the help.
