Go Back   S2000 Club of America Forums > Public Forums > S2000 Chat > The XViper's Den
The XViper's Den Have a technical question about your S2000? Just ask the experts.
Old 12-27-2006, 12:26 AM
whitefun's Avatar
whitefun whitefun is offline
Club Member
ap2 oil consumption
hi, just wondering if the oil consumption in my 2.2 is in line with what others have experianced. i live in phoenix so the first change was done at 3500 miles. no loss of oil from new to 3500. just checked fluid level and after 1000 miles it is down 2 diamonds or 2/5 of a qt. i estimate usage of 1 qt between 2000/2500 miles of driving. i believe this is in line with the manual but i am curious about what others have found and if it seems normal to have used none until 3500 and then start using oil after the first change. thanks phil
Old 12-27-2006, 12:48 AM
batguano's Avatar
batguano batguano is offline
Carolina Chapter Charter Member
I have an AP2 and have had no oil consumption problems. I changed my oil at 1800 miles and very 2000 miles after that. I currently have 21000 miles on my 05.
Old 12-27-2006, 01:04 AM
ninja's Avatar
ninja ninja is offline
Dr. Hobo
currently with 26k miles on my 04, and it hasn't used a drop.
Old 12-27-2006, 01:20 AM
Goku's Avatar
Goku Goku is offline
Lil "Stig" in training.
dont scare the man! Any of you guys drive hard, or use Vtec atleast 2 times a drive? the use of Vtec will change your oil comsupsion a lot. My self for example, I will burn a qt every 2k if I just have fun with the car, if I race I burn up to a qt every 1k. But the oil that you use makes a big difference. I no longer burn any oil at all, even racing with Mobile 1 Synth. When i used plan Mobile I would burn what I have stated. So take that into account too. I have 61,000miles on mine
Old 12-27-2006, 01:47 AM
ninja's Avatar
Dr. Hobo
i use castrol syntec, that may be why i don't burn any. i hit vtec a LOT
Old 12-27-2006, 01:48 AM
Goku's Avatar
well we dont know what oil he is using, and I was burning oil with dyno oil. but the change over to synth I stopped all comsumpsion
Old 12-27-2006, 02:17 AM
batguano's Avatar
Up until the last oil change, I was using Pennzoil and no problem. The last change i put in Mobil 1 synthetic. Yes, I V tech a lot.
Old 12-27-2006, 04:53 AM
repiv's Avatar
repiv repiv is offline
Club Member
I wasn't aware that the manual gave any indication on what normal oil consumption is. Has the manual changed of late?
I would say, even for an AP2, that 1qt every couple thousand miles or so is not alarming, however, the general trend for AP2's is that these are much more disinclined to using oil at all. Keep track of the consumption, based on the type of driving you do, to see if it changes. Like already asked, what brand and viscosity and type of oil did you go with at that last change?
I suppose it is entirely possible that you have a bad PCV valve, in which case, try to have it checked out or even replaced with a new one. They aren't that expensive. If the situation continues, I would suggest getting a "Krankvent" and install that in the PCV line. It's like a high priced PCV valve, but much better in preventing excess oil loss through the PCV system.
Old 12-27-2006, 02:37 PM
trapper's Avatar
trapper trapper is offline
'04 S2k Silverstone/Black
I have a MY04 AP2 and hit Vtec a few times almost every time I go out. During the 7,000 mile engine break-in period with the original Honda oil I burned about 1/2 quart. Haven't burned a drop since and have run about 20,000 miles total.... no track. Used Honda oil up to 12,000 and then switched to Castrol Syntec.
Paul
Running - '04 S2K
Retired - '63 Austin-Healey Sprite, '69 MGB
Old 12-27-2006, 03:57 PM
asnbanker's Avatar
asnbanker asnbanker is offline
S2KCA Treasurer - Life Member #68
I have an 06, and after 24K miles, I haven't burned any oil at all. I used Mobil 1 Synthetic 10w30 after 11K miles. Dyno oil before, but no consumption. I Vtec more then 3 times daily.
Ibherdesign Taipan Widebody w/ ASM A-Shine Frontend, Supersprint Exhaust w/o Resonator, Fujita F5, 18" Work Varianza, Berk 70MM, Berk Thermo Coated Header, Mugen Radiator Cap, Mugen Thermo, Hondata Gasket, Tein Flex Suspension, Alpine 9860, Boston Pro 60, Alpine PDX-5, Alpine NVE-N872A Nav, Alpine Touch Screen, JL Audio 8" Custom Sub
Old 12-27-2006, 04:13 PM
epic333's Avatar
epic333 epic333 is offline
my two cents: i haven't burned any noticeable oil in 15,000 on my '05. dyno up to 13,000; mobil synth since.
Old 12-27-2006, 06:18 PM
GloballyOff's Avatar
GloballyOff GloballyOff is offline
I have a MY '05 8,000 mi. using Mobil 1 10W-30. The car had never used any oil until I tracked it. It used over 1 qt. during 2 days of HPDE (lots of VTEC). Since then it hasn't used any more oil with occ VTEC in city driving.
Old 12-28-2006, 01:30 AM
whitefun's Avatar
Club Member
thanks for all of your input and suggestions.
as you suspected repiv the manual has not changed. i reread it after reading your reply and it only says to check at fillup. i must have gotten my info reading the forum and somehow attributed it to the manual. getting old is tough!! beats the other option. i had the oil changed at a honda dealer when they installed my oem front lip. i believe it was 10/30 dyno oil. told them no synthetic until it gets to 10000 miles. i pulled ouy my reciept and recalculated the miles driven since the oil change. 1200 miles and 2 diamonds down should equate to 3000 miles to use a quart. occasional vtec around town. it does seem that the 2.2 uses very little or no oil according to the replies.
as suggested i will monitor and see what transpires.a new pcv valve and then a switch to synthetic at 10000 and krankvent after that if no improvement is seen with the pcv. don't mind adding a little oil but it will be interesting to see how things progress. this is a GREAT car.
  #14
Old 12-28-2006, 12:53 PM
RUSSO RUSSO is offline
I have less then 2000 miles on my 06 ap2 oil is fine so far.
  #15
Old 12-28-2006, 01:51 PM
emg88's Avatar
emg88 emg88 is offline
X-N.E.R.D.
IMO. Oil consumption has a lot to do with the way a car is broken in. I followed the break-in procedure in the manual with religion. After the 600 miles, I drove it hard. I have not used a drop of oil. I waited until 5,000 miles for the first oil change (I didn't like that). I now have 6,000 miles and have not used any additional oil.
I drove down to the Dragon in NC this past fall. It is a 1600 mile round trip from NJ. There was lots of VTEC and high rpms once there. There was no additional oil usage there either. I am waiting to 10,000 miles to switch to Synthetic (Amsoil).
2005 Silverstone - Mods: Comptech exhaust, Comptech CAI, Comptech strut bar, Comptech rear tie bar, Rick's cross brace, Power Slot Cryo Rotors, Hawk HPS pads, Head Rest speakers, XM radio, Volk RE30 w/RE01R, Work wheels VS-SS for looks!
