Go Back   S2000 Club of America Forums > Public Forums > S2000 Chat > The XViper's Den
The XViper's Den Have a technical question about your S2000? Just ask the experts.
Old 11-29-2006, 09:39 PM
savs2k savs2k is offline
car wont start -_-
so i was driving today doing errans. And everytime i started the car back up it was having a harder and harder time starting up. until i got home and it just wouldnt start anymore. The battery is at 12.5v. I hooked up a jumperpack anyways and it still doesnt start up. Stock alarm. My car is 01.
I thought it was the alt but it cant be if the battery has enough power to crank. Any ideas?
Old 11-29-2006, 10:08 PM
desmo4's Avatar
desmo4 desmo4 is offline
Heisenberg's uncertainty principle
If the battery will spin the starter and engine, you must determine wether you have a spark or fuel issue. Since both of these issues are controlled by the PGM injection computer, it could be the cause. However you need to have a PGM tester to verify what is really going on. I am only guessing. So it's dealer ho.
Jonathan
MY 00 #3510
[SIZE=1]Mugen Airbox, Headers, Exhaust, Pressure Plate,LSD, Radiator cap NZ dampers, Thermo SW seat track and Thermostat. Sampco intake pipe and radiator hoses, Swift sway bars, Stillen rotors, BBS JDM Forged Wheels.w/ Potensa Re=01R's Nextgear Intake manifold gasket, SPA gauges, Alpine IDA-X001, KCE-350Bt BT adapter, Focal 165-K2P 6.25" Speakers, Phoenix Gold ZX475Ti, Recaro Profi SPG w/Sparco 6 pt harness
[/size]
Old 11-30-2006, 12:35 AM
the starter was barley going. It didnt have enough power to start the car. im positive it wasnt a fuel/spark probelm.
Old 11-30-2006, 01:29 AM
desmo4's Avatar
Well then charge the battery and see if it will start.
Jonathan
MY 00 #3510
[/size]
Old 11-30-2006, 03:06 AM
repiv's Avatar
repiv repiv is offline
Club Member
Further to the PM I replied to, I would like to clarify that it is the starter motor that is having a hard time turning, right? Since you said that once it starts, you can drive it around fairly normally. I would suggest that your alternator is working but your battery is not taking a charge. Depending upon how many accessories you are running on the car (big stereo, headlights, air conditioning, etc.), the charging system may not be contributing enough for your car's electrical needs during certain conditions and it may still be drawing battery power at times and simply draining it and not charging back up. Do the checks I mentioned in the PM and let us know what you found out. As I said, your jumperjack may not be able to provide enough power to crank the starter motor if your dying battery is diverting too much power in an attempt to bring itself back up (but can't).
If you jump start the car from another car, it may work. If it doesn't then disconnect your negative terminal first and clip the jumper cable onto a solid metal part of the engine. That way, you get no juice going into the bad battery. It should start easily and if it does, you have your answer and new battery is in your future.
